search takes a long time
lenskaraoke
I've just downloaded the latest version ( 1.0d48r4)of kjams and the when I search for a song in the library it is taking about 40 seconds before I can select a song.
Tiger or Leopard? intel or ppc? what is your MHz?
lenskaraoke
okay
well, i can make diacritic insensitive searching optional if you want, i believe that is what is slowing things down.
there are in fact several things i can do to make the search go faster
i'll see what i can do tonight. it may not get fixed but i'll have more info.
lenskaraoke
yes leopard's search is faster
The burning issues have all been resolved, which you would see if you read the version history blog for the upcoming version, currently:
http://www.kjams.com/wiki/History_1.0d49
note for readers who are seeing this for the first time after January 2008: click this link instead, then click the "click here" link.
