A very minor niggle.
When I type "Command M" I expected kJams to do what most Mac apps do i.e. minimise.
I didn't
The orange clicky worked and the double clicky top bar worked but the keyboard shortcut didn't.
I guess it doesn't matter but if you could add it to the very bottom of your list....
CC
Minimise
it's been at the bottom of my list since the beginning.
But now, since i have customizable keyboard shortucts, it becomes insanely easy to add. So I just moved it to the TOP of my list.
Well, now it' has even moved OFF the top of my list. You know what that means? That means it's DONE!
