I am trying test out my external drive.
The burn button icon and menu item are both grayed out.
I have installed the pluggin.
Thanks for any help.
I love this program!
Burn Button Grayed Out
if you're on Leopard, it's busted and you'll have to wait for a fix.
If you're on Tiger, did you select the playlist first? note: you can't burn from the library
Plexx E. Glass
Thank you!
Thank you, that was the problem!
