Uninstall kJams Pro Windows
Nick Burrett
Post by Nick Burrett »
Hello
How can I completely uninstall kJams Pro for Windows. I have used both the Windows utility and the kJams setup file. Whatever I do, the next time I install kJams Pro for Windows - all my old producer templates are shown in the Video tab.
It's apparent that using the uninstall program doesn't delete everything :-(
Nick
Re: Uninstall kJams Pro Windows
first, run kJams
then go help->reveal preferences
then quit kJams
then, delete the "kJams" folder (in the preferences folder) (this is where your templates live)
then go to "add/remove programs" and uninstall
then go to your user's "Music" folder
then delete the "kJams" folder in there
