Is there any way to get Producer to properly parse timing on file with incorrect track length?
Trying to fix a few glitches, but every time I use the arrow keys to move the scrubber, instead of moving a single instruction, it jumps to odd locations in the track. Moreover, even if I am able to manually click on just the right place on the timeline, the correct data does not show up in the Inspector window.
After investigation, I noticed that the track length was showing as 7:10, even though the track was only 4 something minutes long. I suspected this error was causing the timeline accuracy issue, so I unzipped the file and looked at the MP3, and it was fine. Both Finder as well as iTunes show the correct track length. I even edited the tags to make sure. But it was still wrong in kjams. I then tried importing the newly unzipped file pair (after various clearings of the audio cache and relaunching) but the new database item also incorrectly listed track length. So I have to believe the error is somehow in the CDG file.
So, first, is this correct, and second, is there a way to fix this, and third, even if not, is there a way to just fix the original font glitch that made me open the track in Producer in the first place?
Re: Is there any way to get Producer to properly parse timing on file with incorrect track length?
send me said files (mp3+g)
So, several restarts and relaunches removed (plus an hour spent trying to figure out which track it was based on dates and lengths and other cues, since I totally forgot which track I was talking about) I managed to fix it in Producer, i.e., the issue magically went away.
So it is some larger Producer/kJams bug, maybe not related to the specific file (even though the time codes ARE screwed up still) and maybe related to all those other screwy things (like D&D not working, etc.).
i can't even speculate without a solid repro case :(
