Long Dash – in name parser Template
karaokeniagara
Post by karaokeniagara »
not sure if this is a bug or I am missing something in editing the song conform.
but I have set the name parser Template to show L-T - R - S To display my file name as Disk-track - Artist - Songtitle
(Notice the Shorter normal - )
But for some crazy reason after I edit a songname in kjams everything changes to a longer –
and when I use the longer dash names in another program and try to add meta info. Results in Bad Zip.
My question is... what do I need to do to get rid of the long – ?
Re: Long Dash – in name parser Template
a long dash is NOT a delimiter, so you could use it for "Olyvia Newton–John" for example, and in the file system you'd get a real, long-dash. so if you ever re-interpreted using L-T-R-S, it would put the entire artist name in the correct field and not split it.
if you EDIT any field in kJams, any dash you enter is turned into a long-dash, to PREVENT it from being saved on disk as a regular dash, which will be interpreted as a delimiter.
you're basically not allowed to use dashes in any editing, because a dash is a delimiter.
