Pre-selecting folder to add from
All my karaoke tracks reside on my HD in a folder called Karaoke Tracks. It would be great when I add a track that the New finder window could be pre-selected instead of me having to choose where I want to add a track from
Re: Pre-selecting folder to add from
kJams is supposed to remember the location where you last added, and take you there next time you go to add. is it not doing that? mac or windows?
It does but I've just found out that if I start to add a track and I navigate to a folder (lets call it 'Johns' folder) but I cancel the action once I've navigated to Johns folder, the next time I want to add a track I'll be taken to 'Johns' folder. I would obviously navigate to the Karaoke folder and add the track. If I then go to add another track I'd be taken to Johns folder again and the only way to correct it is to navigate to the correct folder and then cancel, then when the next time a track is added I'm taken to the correct folder
A bit weird, but there you go
wait so you're saying that it's backward? that if you hit CANCEL it remembers, but when you select and hit OK it does NOT remember?
Yes
okay, i'll investigate and let you know. note i'm swamped right now, it'll be a couple weeks.
