test lite after testing pro?
grampa
Post by grampa »
I am trying out kjams pro but would like to try out kjams lite I have uninstalled kjams pro do
i just download kjames lite now, or will there be a problem if I do, thanks
Re: kjams lite
you don't need to uninstall, you can have them both installed at once. only run one at a time, as they use the same database.
grampa
Re: kjams lite
Post by grampa »
I got another stupid question, does Kjams save a selection to the hard drive once you play it ? the reason I ask is I can play a song from my external drive and then disconnect the external drive and select the song again from playlist and it will play again, or is that something that will correct itself when I buy the program.
Thanks Dave
Re: kjams lite
kJams caches the most recent several songs.
See point number 6 in this list
grampa
Re: kjams lite
Post by grampa »
i went to Preferences. Audio, but where the caches says 20 and a up and down arrow mine has 25 and no up and down arrows
Re: kjams lite
what is it you're looking to try to do? there's no need to adjust the size of the cache. do you need to move the cache to an external drive?
