Saving songID and PLI to mp3 tags and xml sidecar.
Why, you ask. Well, this would allow for transferring the database more easily to another computer, such that history and other playlists could be maintained, especially when rebuilding the library from scratch.
(This would also require, of course, the ability to add these records to the files retroactively.)
Re: Saving songID and PLI to mp3 tags and xml sidecar.
there is no stop-gap measure for this, the entire feature must be completed or it wouldn't work. i have a comprehensive plan to enable rebuilding without losing your playlists, which includes and supersedes this request. it's on the list. :)
Good enough for me.
