Problems with new users signing up.
daedalus
Post by daedalus »
Dave,
The problem started last night. With kJams Pro we have the server option enabled and have a request pc setup. The problem is when a new singer creates a new user it creates a entry in the kJams list, but will not add the user in to the drop down if they come back to request a new song.
OS: OSX 10.10.4
kJams Version: Pro 1.0.1 b82
Thanks,
Wayne McLemore
Re: Problems with new users signing up.
the user must create a password for it to be in the list.
also, try hitting "refresh" ?
try it right now and let me know!
daedalus
Post by daedalus »
Thanks. That worked.
Sorry to have bothered you.
daedalus
Post by daedalus »
I am to inform you that when I tested that I didn't have the macbook in front of me and now I'm here at the karaoke location that the problem is still occurring. I did notice that the names do appear after I log off and relogin to the request pc. This is happening from both a windows xp computer and my personal laptop which is running debian linux.
I was told that this started after the last update. If that was the case what would be the easiest way to downgrade?
crap, you're right. i'm on it. will report back ASAP
update: fixed, will be in tonight's build
