Possible purchaser Q's
Doo Wop Phil
Post by Doo Wop Phil »
Thinking of purchasing Kjams Pro for my MacBook Air. A couple of Q's:
1. I am a solo entertainer and will be adding song lists from my Lenovo LT over to my Mac using a flash drive. Think that will work?
2. Using Siglos Pro on my Lenovo which does not save a key change. Kjams Pro does. Correct?
3. Using a Voco Pro LTV-5 as an additional monitor with USB and MIDI converter box from Sabrent. Will I be able to get a
converter cable to work from my Mac to the Sabrent, then to the Voco Pro LTV-5?
4. Once I purchase Kjams Pro will I be able to also change my program in my Lenovo to Kjams Pro?
4. Anything else needed to download/operate Kjams Pro on my Mac?
Thanks for your help.
Doo Wop Phil
Re: Possible purchaser Q's
adding song lists ... to my Mac using a flash drive. Think that will work?
of course, just use "add to library" then pick "copy"
https://karaoke.kjams.com/wiki/Add_To_Library%E2%80%A6
of course!
https://karaoke.kjams.com/wiki/Pitch_and_Tempo
Voco Pro LTV-5 ... with ... converter box from Sabrent
possibly, but that's a lot of hassle for no benefit, plus that thing is 5 INCHES across? way too small IMHO to give a great experience to the singer. i'd return that asap and get a regular flat computer monitor or small flat TV (that has a stand). you don't need any of the "extra features" that the Voco provides, and the required converter boxes are just more potential points of failure (and hassle).
one license is good for two computers (used by one person) (ie: you can't give your 2nd activation to someone else)
just mics, a mixer, an amp, and some speakers, and you're ready to go. i also recommend a song subscription
