Two questions
baysvoice
Two questions
Post by baysvoice »
Hello -
I apologize if these questions have been asked before -- I did a search, and couldn't find any related topics.
I have a MacBook Pro, and a separate, external drive with about 50,000 karaoke tracks on it. Assuming that the karaoke files are compatible with kJams, can I run kJams off of the external drive without actually putting the songs on my laptop's hard disk? (I do not need to "burn" or "rip.")
Also -- Can I use one kJams license for two different laptops?
Thank you for your time.
C.B.
Re: Two questions
the info you want is here
specifically the part about "reference"
also: one license is good for one "rig" which may include a backup computer (to be uses ONLY by the same person, NOT to be given to a different KJ in your company)
baysvoice
Re: Two questions
Post by baysvoice »
That's exactly how I plan to use kJams -- on my main laptop, and on my backup.
Thanks for your prompt reply.
Re: Two questions
