Converting raw .pcm FIles to use
jdrmm8400
Post by jdrmm8400 »
My computer crashed a while ago. I was finally able to get some of my songs back but the audio piece is in .pcm format. Does anyone know of an easy way to batch convert the .pcm files to .mps files? KJams does not recognize the .pcm files and will not play them. Please help.
Re: Converting raw .pcm FIles to use
You can use Audacity to reconstruct the mp3 from pcm
