Unable to search song database
TezinOz
Post by TezinOz »
Hi,
At my last show, the singers using the app on their iOS devices were able to login, view their history and favourites and submit successfully.
However, no one was able to search for new songs - the app would simply say nothing found. Anyone else having this problem?
Re: Unable to search song database
it happens if you RIGHT clicked on any playlist other than Library and picked "use for Server Search"
to fix it, right click on LIBRARY and pick that. you can tell if it was WRONG if there was NO check mark next to it.
