Work-around for mpeg-4/mov files
dino
Post by dino »
I see from version notes that it will be awhile before kJams handles import/play of QT files. While most of my files are mp3+g, kJams is the perfect solution. However, an important subset of my collection is Spanish-language karaoke, which is much more reasonably priced in collections of DVD or VCD files. Right now, I'm ripping the discs and converting the video_ts into mpeg-4 for each song and importing them into QMidi (easier to have a play list and to create a song book). I had also tried to demux the files and force the video into .cdg, but I'm not acheiving a lot of success. Anyone know of any good way to do this while QT support is still in process? I have ffmpegx, MTR, and handbrake at my disposal, along with Streamclip.
convert video to CDG
Keep in mind that the CDG bitstream is about 3.6K per second. Can you compress video down that small? Mostly not, I think. But if you *can* squish it down below 3.6kbps, then you should be able to squeeze it into a CDG. But Nobody I know can do such a thing. Don't worry, soon after I do Burning, i'll get QuickTime going too.
dino
Post by dino »
Excellent...yeah, there's no way to do it unless I went back and frame-by-framed it...in which case I might as well just create new CDG video myself. In the end, not worth it. Looking forward to k-rocking the QT.
