Trivial outlier
Trivial outlier
If you do a search for a singer in a venue and and then delete some of the members in that list from the playlists pane, the entry in the search remains, just with all the data missing. However, if you then click the "Here" checkbox, you get a non-fatal assert at 818.
Like I said, an outlier, to be sure!
Re: Trivial outlier
noted
