iPad 1st Gen / iOS 5.1.1 / WtkJams KE
gearswap
Post by gearswap »
Many iPad 1 Owners will run into issues when trying to run wtkjams KE in Kiosk Mode, No Worries though. There is a work around that works perfect.
1) Get yourself a cheap iPad 1 (50-100.00 on ebay or kijiji)
2) Install all the updates.
3) Buy the WtkJams KE (5.00) from itunes.
4) Install Cydia using your favorite jailbreak software. My personal preference is (absinthe-win-2.0.4)
5) Install from cydia (IncarcerApp to lock App to ipad) restricting singers from leaving the app.
6) setup the way you want to activate the lock and your all set.
Enjoy.
(Now you can make Digital Songbook Kiosks on the Cheap)
Re: iPad 1st Gen / iOS 5.1.1 / WtkJams KE
:shock:
