"eSellerate Engine Corrupted"
jesstifer
Post by jesstifer »
Hi Dave,
On my recent startup of KJams I received an error message: "Unable to install eSellerate engine. The engine being installed is corrupted." I click okay and the library loads. But then anytime I try to add a new singer the program crashes. I followed instructions to first auto-update, and when that didn't work, to manually update to the latest version. After download, I get the message, "a required plugin could not be found." The program will still launch. It gives me messages about [* New Singer's] playlists being lost, and then goes back into the eSellerate-download-crash loop.
Should I download and re-install clean, and if so, is there a way to save playlists?
TIA,
Jess
Re: "eSellerate Engine Corrupted"
go to the web site and download kjams, install that, over the previous one. you will not lose your playlists. let me know.
jesstifer
Post by jesstifer »
All better. Thanks for the handholding.
