Update Crash
Mike981
Update Crash
Post by Mike981 »
I have had this issue for a while, when I try to update the latest version when it gets to the unzip it crashes and closes the program. Normally after a couple of tries it will take, but now it won't I tried to do a search on this forum and didn't see an answer. I believe it is possible to update from the website, do I just click the download and it will automatically replace the current version?
Re: Update Crash
sorry it took so long to get back to you!
yes, if the automatic updater fails for any reason, just go download and install the current version from the web site.
on windows the installer will replace the current version
on mac, when you drag the app to the "Applications" folder, it will ask if you want to replace, and the answer is yes.
