back up files
djgusmusictogo
back up files
Post by djgusmusictogo »
also how would i go about backing up all my k-jams files??......should i put them on a thumb drive??
Re: back up files
You should put them wherever you have room. I recommend Time Machine (if you're on a mac)
what needs to be backed up is the "kJams" folder (in your user's Music folder)
you may also want to back up your preferences (Help->Reveal Preferences)
