Sort Column for Singer Passwords
TezinOz
Post by TezinOz »
Hi Dave,
When viewing singers at a venue, would it be possible to add a sort column that shows singer passwords for the server?
This would make it easy to have a viewable list that could be copied and exported. It would work best if the passwords could also be edited in the column view for a particular venue.
Cheers,
Tez
Re: Sort Column for Singer Passwords
no because that would be an obvious security violation
that won't ever happen, due to security.
that *could* be done, but you would not *See* the passwords, they would look like bullets eg: "••••••••••"
