Add new singer = Automatically here
Krisko
Post by Krisko »
Is this possible? I run a hybrid system with the app, and paper.... When I get a singer who's never sung at my show before, I create a new singer, and then I have to tell kJams that they're here... I was wondering if this could be one step.
Re: Add new singer = Automatically here
A simpler solution that works for the majority of cases is to find out their initial song choice first, find that track in your library, context click and add to new singer.
yes, adding a song to a singer auto marks them as here (if you didn't change the pref)
and you can add a song to a new singer in one fell swoop (right click the song)
Krisko
Post by Krisko »
Thanks guys. Didn't know that was there. Used it all of tonight, and it's way faster than the method I've been using. :D
