Hi,
I currently do a 5 hour show with singers using both the server and paper for song requests. The rotation is usually full after about 2 hours.
I want to know if it is possible at this point to switch to a different venue, and then after about an hour return to the original venue without losing the rotation in that first venue.
To clarify, I've been asked to do a special segment in the middle of the show where males must sing female songs and vice versa. I thought that by making a "new" venue it would make it easier to manage. I would give singers in this venue a new server login.
Am I correct in assuming that the server for the first venue will stop and the 'new' venue will become active
Will this work?
I'm using Kjams Pro 1 on Mavericks
Thanks in advance Dave or anyone
Cheers,
Tez
Switching Venues at same location
Re: Switching Venues at same location
yes, that's how it works. ☺ you will have all new singers & rotation in the new venue, and when you switch back you'll be right back where you left off.
