Column widths
Column widths
It would be nice to be able to reduce the column width space buffer. The minimum column widths for many of the columns, IMO, are way too wide. So for instance, the # seems almost three times wider than necessary (which is doubly bad, since you kinda HAVE to have it in the playlist, but it delivers very little useful unique information, Tempo, Pitch, and Duration (and pretty much and column with numeric data) which seem to be almost double, etc.
Basically it seems a static buffer is used, so the smaller the data in the column, the more wasted space.
This is even more important on smaller displays, like the 13"ers, where data columns end up flowing out of the window space, firing a scroll bar, and thus removing the ability to garner important info at a glance.
Again, all IMO.
Re: Column widths
sure, that's a very easy fix. i'll do it for next release.
