Hello, I am having issues exporting and keep getting asked to purchase. I did not export 10 quicktime movies yet. Only 4. I just need a few of these Karaokee songs that are in mp3+CDG format converted so I can open them in Final Cut 10. I have spent hours trying to convert with VLC player and the only thing that I have found that worked was kjams lite I think. I am not positive that the 4 files that I got working in Final Cut were infact exported with kjams lite and I can no longer verify that. I thought this was freeware? I did not use it 10 times or try to export more then 10 at a time. What am I doing wrong? I am not a Karaoke person and I do not need karaoke software for permanent use. I just need to convert a few CDG's. Please help!
Thank you in advance! I am super frustrated!
Having some trouble with the lite version
Re: Having some trouble with the lite version
kJams is trial ware, it is not freeware. There are limitations in the software, until you purchase. Note it's only $40.
You mention you have not exported more than 10 times. Are you saying that kJams is giving you the error regarding the ten-export limit?
If so, email me directly and we'll figure something out for you.
I have had that problem too
I was testing the pro version I guess and exported a few files ( not 10 ) then the next time I went to use it , I couldnt get through the dialogue about over 10 files, I figured I d check and see if the lite version exports files ( then buy whatever one i need ) and I downloaded it .. it automatically went into the same dialogue.
I m not sure what the diff is in the exporting of files... the ones I did on the pro seemed to work ok in my playlists on JOOBIK which i am using to play them on my iPad . can you help ? anyone ?
thanks carrie
thanks carrie
Yes I can help. please email me directly (dave at kjams dot com)
i've discovered a bug that would limit you to 5 or possibly 4 exports in the tryout version. i've fixed it back to 10.
