Is it possible to share the Venue and Singers histories between two separate licensed KJamsPro users? If so, how? Thanks in advance.
note:
I have a fellow KJ that is buying KJamsPro and plays at the same venue that I do on alternate nights. They are purchasing soon and ask me if I could share the Venue's Singers List and History.
Sharing History
guitartattooman
Re: Sharing History
Additional information: I am using a Mac and they will be using a Windows based operating system. Also, if they don't have a certain song in their song library will it still show?
Re: Sharing History
yes but ONLY if one library is a literal clone of the other.
Here is how to clone.
if you have separate libraries (which it seems you do), then no, there is no way to share histories, cuz the libraries don't match.
Perhaps the venue should own the kJams, and just keep the same computer on site?
Re: Sharing History
Or have the installation on an external. OS and all even, if necessary.
Re: Sharing History
okay the unequivocal answer is "no", you can't share the data between mac and windows.
