No sound here but on WMP
tryingcake
Post by tryingcake »
I'm sure this answer is already here, and I apologize. I just spent 30 minutes looking and cannot find it. If you can either answer or link me up, I would be so grateful.
On some selections I do not have any sound. The video works fine. The sound works fine on Windows Media Player.
I really like this program and am considering purchasing it. I just need to work out a couple of little kinks before making my final decision. I am using Siglos right now on my MacBook Pro through Elements but it will not play the 85,000 KMA files I just purchased so I need to find a new program. Siglos will not play the sound either on the same files. So I'm thinking it is an issue that would be comparable with both programs.
I am using 2.0d15 on a fairly new MacBook Pro (purchased in August 2013) version 10.9, 749.3 Gb capacity, 653.82 available
I have installed Flip4Mac
Thank you!!
Dawn
Re: No sound here but on WMP
send me a song file that won't play, and i'll take a look
tryingcake
Done
works fine for me. we'll take a look at your machine tomorrow
