Music Stores within Kjams
chuckster
Post by chuckster »
The 3 of them that are listed, which one has the most to offer of the 3? Which one do any of you folks use for a monthly subscription? Is there anyplace one the web to see all the songs they have to offer? Thanks for the help.
Chuckster
Re: Music Stores within Kjams
It depends on the country to me. I'm in the UK and I personally find Tricerasoft the best, I get a gift voucher for 75 tracks and I've always found that they have the track I want whereas the others don't always have them. If your in another country you might find one of the others better
chuckster
Post by chuckster »
I am finding that the amount of streaming songs is pretty low on the tricerasoft. Would you say that the credits are a better way to go then? I guess it would mean that you're actually purchasing the songs instead of streaming.
just run kJams, view the music stores. you can then see that TriceraSoft has 82,720 (including songs with guide vocals), Karaoke Cloud (formerly Chartbuster) has 14,031, and KaraokeLocker (formerly Sound Choice) 11,163
just use kJams for that, silly :D
yes, TriceraSoft streams ONLY the "SunFly" library, which is currently 11,804 songs. Still, a pretty decent sized library.
if you want to own all your songs and you want the largest selection
correct
