Rowmote Pro Question?
guitartattooman
Post by guitartattooman »
I have Remote Pro but can only get the volume control and track pad to work. Any suggestions or clarification of what this program can actually do or control in kJamsPro? Can you start and pause songs in the playlist?
thx
Re: Rowmote Pro Question?
yes and i'm surprised to hear this, i'll look into it and get back to you tomorrow
okay, tested and it's totally not working for me either. :(
i've contacted the developer, we'll see what he says
guitartattooman
Works GREAT now!
James,
I’ve hunted down the problem and it should be fixed in Rowmote Helper 3.8.7, which is available as of now via www.rowmote.com. You’ll be automatically prompted to update within the week by your current version of Rowmote Helper, but I thought you might like to know sooner.
Please let us know if it fixes the problem for you, too.
Cheers,
Evan
Evan D. Schoenberg, M.D.
CEO, Regular Rate and Rhythm Software
www.regularrateandrhythm.com
wow, that was, umm, as fast as me!
good show!
