Exporting Audio Files
Is there a way to export the Audio files only as MP3 AND change the key down 1
Re: Exporting Audio Files
You can export to quicktime with pitch shifting, then open that up in quicktime and from there export to mp3 (you must install lame)
but no, there's no way to export directly including pitch.
That'll do, Thanks
