"Export All" Bug?
way2fst4u
"Export All" Bug?
Post by way2fst4u »
Not sure this is a "bug" or done purposefully. Why is it when I export all files from a singers' "favorites" or "history", in flat format, it only copies the name.zip? Is it possible to copy the entire filename as it appears? (i.e.- Before He Cheats.zip instead of: SC8991-48 - Carrie Underwood - Before He Cheats.zip)
Scott
Re: "Export All" Bug?
under export settings, set the export name template to "L-T - R - S"
way2fst4u
Post by way2fst4u »
Thanks Dave ;)
Scott
