Mavericks
dreben
Mavericks
Post by dreben »
I'd like to ask, if kJams will be ready soon for the new coming "Mavericks"
Re: Mavericks
absolutely it will
dreben
Re: Mavericks
Post by dreben »
Thanks Dave.
Re: Mavericks
The real question is: will Mavericks will be ready, or will it be as bad as Lion and Mountain Lion at release.
--A great man once said "Snow Leopard was Apple's last great OS. All since then have gone down hill."
Last edited by DeusExMachina on Thu Jul 04, 2013 12:49 pm, edited 1 time in total.
Re: Mavericks
A gray man?
The only thing i'm concerned about is multiple monitor mode. I'll have to install Mavericks on real hardware to test that, as putting it into a VM doesn't enable testing on multiple monitors.
Re: Mavericks
Ugh, ML's autocorrect! (Case in point)
Fixed.
dreben
Re: Mavericks
Post by dreben »
Since I unmark "Displays have separate Spaces" in Mission Control, Kjams has a perfect performance. If the background video is MPEG, then QT has much better performance than ML.
Re: Mavericks
Are you saying you've tried kJams on Mavericks with multiple displays? and it works to drag the video window to a 2nd display? do tell!!
dreben
Re: Mavericks
Post by dreben »
Yes, that's exactly what you mean. Works perfect!
Re: Mavericks
yay!
