File Size
TheWarrior97
File Size
The "size" column on the library screen shows this " - " instead of the actual file size. Am I doing something wrong? Would this show the mp3 size or the cdg size?
Re: File Size
It will show the total size taken up by all of the elements that make the song, This could include audio and video and possibly other assets
It takes a while to calculate the sizes of the files that's why it's not turned on automatically, Also it's a bit of a performance hit to have that turned on
But if you want to turn it on look under the advanced menu, Under the special menu: "scan all file sizes"
