Rotation screen
TheWarrior97
Rotation screen
Post by TheWarrior97 »
Is there a way to allow the rotation "who's singing next" screen to cover the whole screen. Currently I can see the song lyrics around the edges on the entire left side and a little square of lyrics in the upper right corner. Maybe I have a setting wrong or something but it looks off-center.
Re: Rotation screen
take a screen shot of that
are you on a 16:9 screen? or 4:3?
TheWarrior97
Re: Rotation screen
I'm actually on my laptop. But I also get it on my 16:9 screen
Ill do a screen shot
TheWarrior97
Re: Rotation screen
Its not happening on my desktop screen 1680x1050
TheWarrior97
Re: Rotation screen
Here is what I am getting on my laptop and on my big screen. But I don't get this on my desktop screen. I must have the resolution wrong or something. What is recommended?
TheWarrior97
Re: Rotation screen
I wasn't hitting full screen, just double clicking the screen. That seems to be the main problem. There is still a little background show through on the left, very small though.
Re: Rotation screen
are you on the latest version of kJams?
if so, go help->reveal preferences
then quit kjams
in the folder revealed, delete the folder "Producer Templates" (if you have edited any, make a backup instead, so you can fix them later)
now run kjams
it should be fine
