Library Info Question
Athmet
Post by Athmet »
I am using the KaraokeCloud and also have a sizable local library of songs. When I look at the Library without the the "Show Streaming Only Songs" selection in the store menu, I don't see any of the KC songs. When I turn that option on, I also get all of the tricerasoft songs in with it. I, personally, know how to tell the difference by looking for the store label. I am dealing with another KJ that is a bit of a technophobe, so I want to make it as idiot resistant as I can.
I am looking for a way to list the KC and local songs in the Library, without the Tricerasoft streaming songs showing up in the library so I can then search Tricerasoft for possible purchases. Any ideas?
Re: Library Info Question
yeah currently there's no way to do this :(
the only way out right now is to either shut off or subscribe to TriceraSoft.
i'd have to add a new option "Only Subscribed Streaming Songs", which i think would work for you?
Athmet
Post by Athmet »
That would work, or if KC Tethering would just put tose songs into the main Library. Same thing really.
if it was just "kc tethered" then it wouldn't work for folks who subscribe to Tricera but not KC.
note: this is now on the list, but won't make it for 1.0
Athmet
Post by Athmet »
Cool. Thanks Dave.
