Zipping or not?
TheWarrior97
Zipping or not?
Post by TheWarrior97 »
I currently have all my songs as individual .mp3 and .cdg files. I was considering putting them into zip files. Does kjams handle zips any slower than .mp3/.cdg?
Pro's and con's to zipping karaoke songs?
If zipping it is...any suggestions on programs to "batch" zip all the files into individual zip's with the filename attached, rather than doing each manually?
Re: Zipping or not?
yes, kjams deals with zip files just fine
the "slowerness" introduced with using zip files is negligible.
probably not worth your time, really. you'd have to rebuild your library
if you turn on "zip while ripping" then any future songs you rip or re-encode will get zipped.
