VCD Data
VCD Data
I have several VCD's loaded on a windows machine in Kjams. The files were not named when i imported them, will Kjpro do this for me? Do i need to reload them?- Thanks
Re: VCD Data
VCD discs do not have any data on them, unfortunately.
the "menus" that you see when you play in a VCD player do show the song names but unfortunately, that data is not available to extract from the player software.
so, you basically have to type all the info in when you load a VCD disc.
http://karaoke.kjams.com/wiki/Meta_Info
Re: VCD Data
Okay, i know thats what i had to do in the past, was thinking there may have been an update/ easier way of doing it. I'll start getting busy! :shock: Cheers
Re: VCD Data
