I just thought about a folder called "Last Import". So when you have added some new songs to your library, and you want (or need) to edit the meta tags, you can easily do so. So the "Last Import" folder should be freshly filled whenever you use the "Add to library" function. I hope this makes sense
Thanks a lot and Many greetings,
Oliver
