Crossfade speed
Crossfade speed
Is there a way to increase the speed that the volume changes on iTunes and kJams using the crossfade script
Re: Crossfade speed
Yes, just adjust the step variable. The variable fadeSteps is used to set both. Right now fadeSteps is set to 20. Increasing this value with increase the speed at which the two crossfade. Decreasing it will, um, decrease the crossfade speed. This then sets the two application faders
(Theoretically, you could set the two crossfaders to different speeds by setting kJFadeStep and iTFadeStep manually to different values instead of using the fadeSteps variable, but I can't see why this would be desirable. Doing this will just mean that one application's volume will reach max or min well before the other one does.)
So just find this line:
set fadeSteps to 20
and change the 20 to some other value.
set fadeSteps to 20
Last edited by DeusExMachina on Thu Feb 21, 2013 11:13 am, edited 1 time in total.
Re: Crossfade speed
Thanks, Works a treat
Re: Crossfade speed
You're welcome, of course.
