Same Volume for all songs
garfield2344
Is there a way to have all the songs in Kjams play back with the same volume. Some tracks play back louder than others.
Re: Same Volume for all songs
currently, kjams does not listen to and dynamically adjust the volume to seem consistent.
but you CAN manually set the volume of a song so it plays back with that volume next time
https://karaoke.kjams.com/wiki/Volume
Alternately, you can go through your library and normalize all tracks. MacMP3Gain can be used for this, but it can get tedious.
Last edited by DeusExMachina on Thu Feb 21, 2013 11:08 am, edited 1 time in total.
garfield2344
Thanks for the suggestions.
The nice thing about MP3Gain is that it will work on whole folders, plus subfolders. So theoretically, you could do your whole library in one pass. Also, it is not lossy.
The bad thing is that it has no idea what a zip file is, so if your tracks are zipped, you get nowhere. I'll have to look into scripting it.
