Shortcuts
lenskaraoke
Shortcuts
Post by lenskaraoke »
Is there a shortcut to play and pause the selected track
yes
the space bar.
ChurchCat
Re: yes
Post by ChurchCat »
dave wrote:the space bar.
This seems to be a standard now. It works in iTunes and QT too. Even Sibelius (a score writing program I use a lot) has recently changed from using P as a shortcut to using the space bar instead.
CC
lenskaraoke
Thanks for that Dave, it's so much nicer and faster to use shortcuts rather than the mouse. It's good to know it works on itunes as well, it's less commands to remember cheers CC. I will try out kjams tonight at my regular Friday night session........Len
Let me know how it goes!
lenskaraoke
still got teething problems, you know what they say 'If all else fails read the instructions'. I will have another go next week and report back
ChurchCat
Post by ChurchCat »
lenskaraoke wrote:still got teething problems, you know what they say 'If all else fails read the instructions'. I will have another go next week and report back
Just a thought. Some tracks run on for quite a while. If you type "command" + . (period) It stops the track. I used to use the play controls a lot. However these just pause the track and this often led kJams to produce unexpected behaviour.
At one time I was going to request an stop button next to the play/pause button but I have become used to the shortcut now.
CC
there will be a stop button
ChurchCat
Re: :)
Post by ChurchCat »
dave wrote:there will be a stop button
That is good news. I think it will be an improvement. A lot of odd behaviour can be explained by the fact that a track has been paused rather than stopped.
CC
randyj
STOP vs. PAUSE
Post by randyj »
I REALLY like using the ESC key instead of Command-Period
