Fixed song names
Krisko
Fixed song names
Post by Krisko »
Hey guys. I've been using Kjams for a little over a year, but only for stores. Now that I just bought a Mac, I purchased Pro and ready to rock shows better than ever.
I have a question:
I aquired a whole bunch of new music on CD, and am ripping/renaming (which is much easier through kjams than my old setup btw) and then realized it wasn't changing the actual file. I was wondering if there was a way to rename the files to If the way they appear on Kjams. Since it doesn't have it's own book writing software, I'd like to keep using Songlist Generator if I can.
If not I guess I'll have to go rename them again lol
Re: Fixed song names
kjams should definitely be renaming the songs on disk. if not, check your prefs->tags->conform, should be ON
Krisko
Post by Krisko »
Oh shoot.. sorry dave, I was reading the info on the folder and not the actual song.
I'm still new to mac life lol. Songs are in fact changed as I need them.. thanks! :)
yes, i never got around to renaming the folders, as that really doesn't matter and you CAN get around it.
