Deleting
TheWarrior97
Deleting
Post by TheWarrior97 »
I would like the ability to delete all the songs in my library from the main kJams program rather than deleting the folder.
I would also like delete added to the "right mouse button" menu.
TheWarrior97
Re: Deleting
Nevermind the first request, it is already updated. :)
Thanks Dave
Re: Deleting
if you hold the command key while deleting, it will not ask. but i recommend against that, FAR better to start from scratch by throwing out the "kJams Library" folder.
the delete function in the context menu will probably not happen before 1.0
