Is there a specific file i can download to save Singer History? I recently deleted songs from a history thinking it was the Tonight section. Would have been nice to restore the history. Thanks in advance!
Jim
Singer History File Saving?
Re: Singer History File Saving?
i don't think "download" means what you think it means. refer to the glossary to ensure you aren't saying something you don't mean.
I think you mean "restore from a time machine backup". presuming this is true, yes, you just need to restore the "History.xml" file inside the singer folder. run kjams, find the singer, right click on them and go "reveal in finder". then quit kjams, then restore the "History.xml" file.
guitartattooman
Yes, you were right. Thanks!
