Windows Tryout 1.0a01r11
way2fst4u
Post by way2fst4u »
I am trying to add tracks to the library on a friend's windows machine. I keep getting the following error:
"there was an error opening the file."
She is trying to use the tryout to practice her songs. I lent her copies of the songs she sings. I am unable to add ANY tracks.
Thank you.
Scott
Scott
Re: Windows Tryout 1.0a01r11
please list the steps you're taking, or edit the below to match EXACTLY what you're doing:
have a folder on the internal hard drive that has ONE song inside (a zip file, or an audio+cdg file pair, the file pair must have the EXACT same name)
run kjams
go file->add to library
navigate to that folder
pick it
when kJams asks, pick "move" (or pick "reference") <-- which one do you do?
kjams adds the song to the library an all is well.
please edit the above steps to match what YOU are doing. cuz the above works fine for me, so you MUST be doing something different.
way2fst4u
Post by way2fst4u »
Mind you, I have pro on 2 Macs with no issues anymore :)
I have a folder on the drive with ALL her Karaoke zips in it. I go to file->add to library
I navigate to that folder
I pick ONE of the tracks, and get that error.
Scott
first: try the rogue. in general, always try the rogue before reporting a problem because it may be fixed.
if the rogue does not fix it, then quit kjams, then run again, re-cause the error, then go help->send log file. be sure you CHANGE the subject line so it does not have the words "crash report" in the subject, otherwise i will not see it.
way2fst4u
Post by way2fst4u »
sent log...same error.
Scott
i did not get a log file from you. did you change the subject line?
do it again, and in the new email, change the subject line
and in the email say "this is way2fast4u from the forums"
way2fst4u
Post by way2fst4u »
Yes I did. I will resend.
Scott
never got any re-send. (the two recent ones were about producer, already replied to them)
Mikesch
Post by Mikesch »
Hi
have same issue if i add single song to library by doubleclick on it
if i only single click on cdg file and then press the, i guess in english it't the, open button
it works fine
then follow the instructions i replied with above. i need the log files
