Feedback on Airport Express as kJams router
reddroki
Post by reddroki »
Hi all,
We're currently using a Linksys WRT54G wireless router and I'm getting the feeling it is heading slowly into the bit bucket.
So, which brings me to a question or two:
• Would the Airport Express (current model) work as a wireless access point in venues where there isn't an open wireless access point?
• Has anyone used the old Airport Express in this capacity? (that's the model that hung off of the wall via it's power plug, currently a good deal at the Apple Refurb Store).
• I assume we could follow the directions elsewhere on this site to create an Ad-Hoc network with either. Is that correct?
• If you have used it, does it work well with wtkJams app?
We just want to set up the PA and plug the router into the wall and have it work consistently with the two iOS apps, wtkJams (preferred) or iJams (when the former doesn't work and that seems to be in venues where we have to use the above Linksys).
Thank you for any feedback and have a Great Thanksgiving y'all! :D
kind regards,
Mark & Anita
Host: Would you like to sing a song?
Customer: Oi! There's not enough liquor in this pub for that!
Host: Hmm. You or Us?
Re: Feedback on Airport Express as kJams router
AirPort Express should work just fine, yes.
old one will work too.
an APE is NOT an ad-hoc network. it's a real network.
works great with wtkJams
reddroki
Post by reddroki »
Hi Dave,
Thanks for the quick reply. Black Friday is coming and I hope to score one or two of the old Airport Express. Have a great Thanksgiving and don't eat too much turkey or if that's not on the plate, then not too much tofuta-turkey! 8^)
cheers!
Mark & Anita
