Error saving Songs.ktd
guitartattooman
Post by guitartattooman »
There was an error saving the file "Songs.ktd". "File Not found".
After running "Reinterpret names" on about 600 songs the above message pops up during reopening of kJams. Like dozens of times when watching "Push Meta Que" in the "Activity Window"
Any idea what is wrong or what I can do to fix?
Jim
guitartattooman
Re: Error saving Songs.ktd
I also end up with 59 each "Songs Not Renamed" in a new "Playlist folder" each time I open the program.
Last edited by guitartattooman on Thu Nov 08, 2012 4:06 pm, edited 1 time in total.
guitartattooman
the message is also randomly showing up during operation of the program.
hmm. the only way i can fix a bug is if i can reproduce it. the only way i'll be able to reproduce it is if you can figure out how to make the bug happen consistently. eg: "if i do these 5 steps, the bug will always occur". can you figure out those steps? if not, i probably won't be able to help.
