Corrupt files again...?
way2fst4u
Post by way2fst4u »
OK, I know there is no way to "fix" corrupt files with kJams. If I were to re-rip, or re-download a NON-CORRUPT version of said file, can it be replaced and will kJams then recognize it as not corrupt? What is the best way to replace corrupt files then re-add them into kJams?
Scott
Re: Corrupt files again...?
yes
if you just rip it, and the meta data is exactly the same, then it will replace the one that is there
if you procure it otherwise (outside of kjams) then, in kjams do "reveal in finder", then copy the file name from the old to the new, then replace the old with the new
way2fst4u
Post by way2fst4u »
Thanks Dave! Rebuilding was the right move!
Scott
way2fst4u
Post by way2fst4u »
How do I get it out of the "corrupt files" playlist once it plays and is recognized?
Scott
if it plays, you can just manually delete it (select, press delete)
way2fst4u
Post by way2fst4u »
I also have 200+ files that have extra characters in them (CB6+40037, CB6+40038...etc..etc...). I have to do them disc by disc right? If I highlight all that need to be changed, it will change them to the same disc #...?
Scott
please call during office hours and we'll go over your specific use cases
