Checking purchased opens safari
When I click the the purchased box in Tricerasoft, safari opens KaraokeDownloads/Previews/ and a part of the track plays instead of the box getting a tick
Re: Checking purchased opens safari
sorry, please define "the purchased box in Tricerasoft" ? perhaps a screen shot? are you DOUBLE clicking? or single?
I mean the box in the purchase column in the Tricerasoft window
that is not set by you, that is automatically set only for songs that you have purchased. that column is disabled, did you not notice that clicking in it does nothing? seems to me you're double clicking on the row, which will launch the audio preview.
Ok. I thought I could check it for tracks I've bought. So when I buy a track from Tricerasoft is that check box supposed to get checked automatically
in the library, yes. not in the music store (tho perhaps it should). in fact, that column isn't supposed to be showing in the music store itself.
