Custom LAME Preset
Dr.Rhythm
Custom LAME Preset
Post by Dr.Rhythm »
I created a custom preset with 256 VBR and after which no matter what I do to try to change my custom LAME preset. I always get 256kbps VBR mp3 files. I tried deleting my preset and recreating it with other settings and I still get 256 VBR files. I even quit kJams and deleted the rtm file that was created when I made the preset and then launched kJams again and created another new preset and still I get 256 kbps VBR mp3s.
Dr. Rhythm
*sigh* okay it's on the list
eeeks, that is, well, lame.
try restarting.
meanwhile i've put it on my list of things to look at., thanks!
Dr.Rhythm
Post by Dr.Rhythm »
I have not tried rebooting but I will try that. I did of course relaunch the application.
Dr. Rhythm
also
may i assume you installed LAME from the download you got from my site? and that you either had never installed it before or you un-installed any previous installation first?
Dr.Rhythm
Post by Dr.Rhythm »
I'm pretty sure I downloaded LAME from your site. I rebooted and no joy. I could remove my LAME install if you want and reload.
It's currently installed here:
/Library/Frameworks/LAME.framework/Versions/A/LAME
The receipt shows, 1.4.1 Lame Component Installer
I just rebuilt my computer before I installed kJams so there's no chance I have any other versions of LAME on my computer.
Dr. Rhythm
welp
all i can say is it's on my list of things to investigate. i'll get to it for sure.
Dr.Rhythm
Post by Dr.Rhythm »
Okay no problem. I'm happy with the 256 bit VBR files.
Dr. Rhythm
still it is strange
i'll probably be able to look at that bug in a month or so
